- May 23, 2015
- 25,753
- Plaster
- Pentair Intellichlor IC-60
Would it be a problem to let the slide run, even if it's just a trickle? That would be best.
As for the stairs you have, just make sure you soak them a little in bleach solution to get them clean. TFP always recommends that Baquacil conversions pull all the hardware out of the pool and clean it separately anyway.
Glad to hear you're passing OCLT. Definitely give it one more day to be sure and then on to the filter sand change.
