Moved from here
Timely topic. I've been on the fence about switching from liquid chlorine to a SWG. I currently have a 15 gallon holding tank with a Stenner pump that is plumbed into a cap where the in-line chlorinator used to reside (never used and didn't want, but the pool builder put one in, anyway). While the 15 gallon tank makes chlorination convenient, I'm getting tired of battling the salt buildup that occurs inside the plumbing at the injection site. It seems like I'm always having to take things apart to clean out the small diameter tubing, replace the duckbill valve inside the injection port, replace the injection port, etc. All of that has led to slow leaks that drive me crazy. Plus, I get tired of chasing liquid chlorine every month - our Walmart is iffy at best and the nearest Pinchapenny is 40 miles away.
I'm pretty anal about chemical levels and keep everything right in the middle of the "ideal" ranges, though after reading one of the threads on the second page of this forum, I'm going to let TA fall from 70 to 50-60 and see if that helps keep me from adding so much muriatic acid. Other than bumping up CYA and keeping CSI around -0.3, it doesn't seem like there's much else to it from a chemistry standpoint.
My pool is a plaster 13,500 gallon pebble finish, so the IC40 would be sufficient. My pump is Hayward single speed and I typically run my pump 4 hours a day in the off season and 6-8 hours in season because we're always in it and like to keep the water features on. I have the basic Intermatic dual timer setup and zero automation/connectivity on our pad. From what I've been reading, it looks like I just need to make sure that the IC40 is wired into the timer for the main pump so it's only powered while the pump is running. There is ample space in my pad and plumbing to install the SWCG, especially if I add in a loop and mount it vertically. I live in the Houston area, so my pool never closes and the only time the water temp would drop below 52F would be during very infrequent cold spells, at which point I'd just have to supplement with liquid chlorine.
Is there anything I'm missing? Jim's link above has the system priced a hair cheaper than Marina. Is there benefit of going with an IC60 for longevity, or would the "overkill" cause issues?
