I currently have a Speck ES90-II pump with a US Motors EZ48 motor with a THP:1.0. I have 1.5" PVC piping and the pressure gauge on my sand filter is showing around 15-17 psi at the moment. I have a ~15,000 gallon pool with one return by the stairs, one skimmer and one port about 16" down near the deep end of the pool. No floor drains or water features. I have a SWG. My pump currently runs on 120V, but I do have 240V available at the pump location. My SWG can also run on 240V
I would like to switch to a variable speed pump. I'm considering the Pentair Whisperflo VST, I know with 2.6 THP it is oversized for my pool, but I figure I can run it at lower speeds, and the VST seems to be a bit newer in terms of communication connectivity.
A few questions:
Christian
A few questions:
- Do you think this pump is a good choice, or should I go for a smaller one?
- Right now my SWG runs whenever my pump is on (it does have a flow switch as well) since they are both on the same timer. As I understand it the Whisperflo is permanently powered so that it could have a program with various speeds at different times. Is there a way within the Pentair system to turn on the SWG at a certain RPM? Would a Current Sensing Relay be a good approach?
- If I want WiFi access to the pump operation and programming, is the IntelliSynch the cheapest option? Will it provide any functionality in terms of triggering the SWG?
- If I want to use the NodeJS Pool Controller, can I interface directly with the RS-485 on the pump, or do I need the IntelliSynch board or some other automation board?
Christian
