Hello TFP:
I'm having part of my pool deck removed to make space for a new addition for the house. The contractor (demo guy) was SUPPOSED to SAW CUT the pool deck prior to excavation work, but what he did instead was use the bucket of his excavator to slam down on the pool deck and then lift up on the concrete deck in order to break it. I just happened to look out the window and see that in one instance, him lifting the concrete in this manner caused an entire section (between compression cuts) of the deck to lift up, all the way to the coping. The pool has entry steps at the end where this work is going on. I took some pictures and it clearly shows the deck separated from the coping in various spots, along with cracks in the deck.
Can the coping be repaired in sections or does it need to be repaired all around the pool? The pool was here before we bought the house, so I don't know if the concrete decking was poured onto the frames that support the pool walls. What other damage should I look for and who would you call to assess the pool structure to determine what needs to be repaired? What's the proper way to repair the deck?
Thanks in advance.
Thanks in advance.
