I’ve been reading a lot about containing ph by lowering total alkalinity which should lower the ph ceiling (an upper limit on how high ph can rise). So that I don’t have to add acid as often.
You can read more about it here if you are unfamiliar. Containing pH vs. Controlling pH in a Pool
My question for the board is… I recently discovered my fill water has an alkalinity of 140. If I wanted to maintain an alkalinity of 60-70 is this basically impossible due to the fill water? Are there any other solutions to keep alkalinity low with this type of fill water?
Or am I stuck adding large amounts of acid because the high alkalinity fill water will constantly drive total alkalinity up which will always make large amounts of acid necessary?
