- Jun 8, 2020
- 590
- Plaster
- Pentair Intellichlor IC-40
I've been researching different solutions to the deterioration concerns of sandstone based rock being used around pools, and thought I'd start a thread to open up the discussion, and get some input from folks who understand this much better than I do.
There seems to be a lot of discussion in the forums on the fact of 'low quality rock', or 'soft rock', or 'sandstone based rock', etc ... deteriorating over time when used as coping (and in other applications .. ie: waterfall, etc), around a pool. Sure, some folks attribute it to salt water, others say it's the water and not the salt, etc ... But in thinking through this, I'm not sure it really matters if it's water or salt water, or both ... and whatever solution is best to address it, should be best for both scenarios, correct?
I started thinking about all the work which is done in the realm of building preservation, where old stone structures (buildings, statues, monuments, etc ...) are preserved by historical societies and such. Certainly, they must have an approach that is better than applying some $30-$50 sealer to the stone.
@Dirk had mentioned in a previous thread that his mason friend suggested he use Prosoco OH100 on his flagstone coping to address dusting and flaking. I won't speak for him, but his reports have been that it worked very well on all but one of the stones they applied it to. So based on that, I was considering having this done to my flagstone and moss rock, but only if I start to notice degradation (my pool is only 25 days old right now).
Now I'm wondering if I should do something as preventative instead of reactionary though.
In my research on how historical structures are preserved, I can across some interesting information on nanoparticles, and how nanotechnology is being used to preserve cultural heritage sites. In this article, it specifically addresses using nanomaterials for stone consolidation purposes, but seems to use a different chemical compound than the OH100 product uses.
Here is a link to the article: How can nanotechnology preserve stone cultural heritage sites?
And here's a quote from the article, describing the chemical approach:
Comparing that to the Prosoco OH100 product's approach:
So it seems the OH100 product uses silicon dioxide as the binding agent, while the nanomaterial approach example in the article, uses calcium hydroxide nanoparticles, which after penetrating the stone, transform into calcium carbonate mineral phases such as calcite and aragonite. It seems the article suggests this approach was used for limestone, becasue the resulting binding agent is the same material. So does that mean there are other nanomaterials for other stone types? hmmm ...
Either way, I'd be very interested to understand which of these approaches would be better suited for stone which is in contact with pool water. Obviously, I don't have a strong enough chemical knowledge base to understand the impacts of either of these being used in and around a pool, so was hoping to get some input.
I also think this topic (ie: deteriorating stone around the pool) pops up with enough frequency where having a recommended treatment approach for the concern would be valuable to the community. As it stands today, when this topic pops up, the responses are pretty varying. Some say "use a good sealer", others say "you chose the wrong stone", some say "it's because of the salt (if SWG)", other say "it's natural water errossion and nothing you can do about it", etc, etc ....
Usually, the person with the concern will then research sealers, because that's really the only thing they can do ... but even the most durable sealers don't seem to address the root issue. Or if it does, it seems to be a temporary fix until the sealer wears off after a year or so. Not to mention sealers can also negatively impact the look of the stone as well.
So ... thoughts on these two different consolidation approaches?
sustainable-nano.com said:Consolidation
Nanomaterials used for consolidation can be thought of as “fillers,” like the packing peanuts that fill the empty space in a package sent in the mail. These nanomaterials fill empty pore spaces and mimic the original stone material. One common consolidation material is a product based on calcium hydroxide nanoparticles (Ca(OH)2 NPs). To restore damaged stone artifacts, we can spray the calcium hydroxide nanoparticles over the stone’s surface or apply them using a brush. The nanoparticles sink deep into the pores and cracks of the stone. The power of these nanoparticles is their ability to transform into calcium carbonate mineral phases such as calcite and aragonite, the major minerals of limestone, through a reaction with atmospheric carbon dioxide in the presence of moisture:
Ca(OH)2, aq + CO2, g → CaCO3, s + H2O
(Calcium hydroxide particles in solution plus carbon dioxide gas goes to calcium carbonate plus water)
In this way, Ca(OH)2 NPs are often used to restore stone artifacts and buildings made of limestone, because the properties and chemistry of the filler will match the original artifact. The Megalithic Temples of Malta, the Bust of Nefertiti, and St. Paul’s Cathedral are all examples of cultural heritage made from limestone. Ca(OH)2 NPs used for limestone consolidation are an excellent example of preservationists matching the filler material to the stone material to achieve better compatibility, effectiveness, and treatment durability.
prosoco.com said:PROSOCO Conservare® OH100 is a ready-to-use consolidation treatment that stabilizes masonry by replacing the natural binding materials lost due to weathering with silicon dioxide. OH100 penetrates deeply, does not form a dense surface crust, and retains the substrate’s natural vapor permeability. It is also an effective pretreatment for friable substrates that need to be strengthened before cleaning, patching or coating.
