Just changed out the water in my 24,000 gallon, commercial, gunite indoor pool which we were previously using bromine tabs through an off-line automatic brominator. For a lot of reasons (the most being the accumulation of DMH over time). I also just installed a paramount UV-sanitizer sized for the pool and have it set to run during the day while bathers are in the water. I also purchased and installed an in-line zinc anode as well. So far I am just using liquid chlorine to sanitize and adding small amounts of dry acid to control the pH and try to keep everything at 7.4-7.5. The water has only been changed for about 1 week and I am looking for alternative sanitization systems. I would rather not use a SWCG due to potential problems with my concrete deck and corrosion of our ADA pool lift, lights fixtures which are old, etc., and was looking into an ORP-based system that uses liquid chlorine and O2? Any suggestions would be much appreciated as I would rather not start using the brominator again as I would have to shelf this until I changed the water again.
Thanks in advance!
Thanks in advance!
