My pool company installed a Jandy VS 2.7 HP. I asked if it was Aqualink RS compatible; they said yes before install but now are backtracking and saying I have to update the system (now that I’ve paid $2300 for the pump and labor!) I don’t think this is true based on the manual; the PDA even has VS options.
If they don’t budge on the new system upgrade I’m going to finish installing myself. I understand the pump needs to be connected via the RS-485. I have an open spot on the multiplex board (2nd pin is not wired to anything) and an empty slot on the main board.
The multiplex appears to be connected to the main board (“pump 1” on RS board), pda receiver (external) and chlorine generator.
Can I connect the pump directly to the multiplex board, or should I use the empty slot on the main RS board? If so, can I just move the unused multiplex pin?
They did install and ground the pump.
