Hi all,
Just got pump running and want to get pool ready for a month of use before closing. What a project!
I could really use some help if you could spare me a few minutes! Thank you in advance for any advise!
I have bought 2gal muriatic acid, 5 lbs cya, 9 gal bleach, borax and baking soda so think I have what is needed.
I have read pool school many times and have now entered ph of 7.8 and ta of 280 into pool math calculator. (yes it took 28 drops to change color red.) Have the tf 100 kit. I understand i want to address ph and cya to start and then chlorine.
Pool math says not for startup so Im confused and don't want to apply chemicals unnecessarily. Why is that the case? Cant find anything for startup calculations.
Says to add 22oz of 31.45 20% Baume muriatic acid(which I specified) to lower ph and apparently TA.
Says to add 48oz of cya which will be through sock in skimmer.
Questions
1 Do I use this calculator for setup though it says not to? If not, what do i do?
2 Do these figures seem accurate for startup?
3 Is my course of action correct
4 Is there an easy way to add muriatic acid? Gloves and measuring cup? Seems pretty nasty to put in pool. Is there another method of adjusting ph and TA?
5 I've read that if cya and chlorine are good, I can swim right away. Is Sunday a possibility? Any other issue to be concerned about?
6 If you have any other words of wisdom for me, it would be greatly appreciated.
Love the site and im 100% on board. Just a little nervous adding chemicals to start and dont want to screw it up now.
Hoping for a real hot September. lol.
Go Cubs! dont hold that against me
Questions
