Hi Pool Gurus,
I'm a pool newbie looking for some wisdom. After performing my first test with my TF100 kit a few days ago I found testing to be a very straightforward process and being a number guy, I can't stop testing now. I'm so concerned about my FC and CC numbers that I just keep performing tests and end up doing all of them every time. I realize this may be overkill, but tonight will be my third OCLT. After my first one 2 nights ago I believe I had completed SLAM as I had a 0 for CC. The next night I had .5 for CC and I just recorded values for one more OCLT hoping to see 0 again.
After testing my water tonight here are the numbers:
The TA value has me concerned a bit, but it hasn't moved in the 7 tests I've performed so far and I'm hoping it is related to my attempts at balancing pH. Where I'm really looking for some help is what to do now? My confusion lies with how much bleach I need to know I have to add without having to run the FC/CC test each time or is that what we have to do? Do those of you with pools just get a feel for the amount you add at whatever frequency and if the pool is used by X number of people then you add an extra cup or something? I found the TF100 kit seems to have plenty of chemicals for me to test twice daily for at least a few more weeks, but I'm kinda hoping to not have to do this now and actually start enjoying my pool...
The other thing I'm confused about is that whenever I clean my cartridge (daily, sometimes twice daily) I'm finding living bugs. There's nothing in the pool I've found, but these things are all over the cartridge and I'm guessing they are feasting on the material caught in between the pleats that I can't wash out. Isn't this something chlorine should take care of?
Thanks for any input!
Jason
BTW - The TFP pool app rocks. Happy subscriber here!
- FC 8 (High end of target FC)
- CC .5 (Pool was used a few hours earlier)
- pH 7.9 (Down from 8.3 this morning, added Clorox pH Down tonight to lower it further overnight)
- TA 240 (Is this bad?)
- CH 200
- CYA 50
- 79 degrees
Jason
