OK
So I refilled, and ahh som'd my "spa" and now I'm trying to get the chemistry correct again.
I had shock level of bleach in it and found that the PH test (R-0014) turned magenta
I uncovered the spa for about four hours in full sun and sanitizer levels went to ~0
I used PoolMath to get my water to
PH 7.5
TA 80
CH 130
And my test strips were saying that FC was between 0 and 2 depending on how cross-eyed I looked at it.
I don't have a test for FC as I normally run bromine
Things were looking up
I decided to go to the next step and added the bromine and ~ 2oz of bleach to activate it (from low FC level)
Looking good but the sanitizer level went high around 15ppm (5 drops X3 for 25ml sample) on my DPD test (R-870/R-872)
added floater with three 1" bromine tabs
Ignoring the non-perfect reading on the Bromine.
TA and CH stayed pretty much the same as did the PH
On to the Final Initialization ... ...
Added 24 oz (by weight) of 20 Mule Team and 26 oz (by volume) of 14.5% MA
PH went magenta
Bromine went to 39????? (13 drops X3 for 25ml sample)
What????
OK, been here done this
Uncovered spa and let the sun bathe it in UV
Bromine went to NIL (<2 drops X3 for 25ml sample)
PH still magenta
Next Steps?
PH 7.5
TA 80
CH 130
PH went magenta
What????
PH still magenta
Next Steps?
