Confused about course of action- help please!
Amorey
1
Indianapolis, IN
Hi all!
We have a kayak pool with that blasted frog system. We are dealing with increasing algae issues. I’ve attached our most recent testing and plugged it into the pool calculator.
I’m really confused- do we focus on one issue or do we follow the SLAM method?
Also- how soon should we see results?
Thanks so much!
Welcome to TFP Amorey!
We can help you clear up the pool, but you really should get rid of the Frog System.
Can you confirm how you obtained the test results? Which test kit do you have?
If the results are from a TFP recommended test kit, did you do a "diluted" test for the CYA result? If it's a valid result, we'll recommend draining/exchanging a good percentage of your pool's volume to get the CYA level down to 30.
You will need to follow the SLAM Process, but you'll need to make some adjustments to the chemistry first.
Please take a few minutes to complete your signature. It will help us help you.
