How much condensation would you say is normal under a pool liner? We installed the XPS foam boards on a really hot day and the boards were hot when the pool was spread out to relax in the sun. Once it was up and I started to fill I noticed water under it after about 2-3 inches. Its under 2 sides as far back as I can raise the liner up. I stopped filling because I don't want to waste water. After 3 days it honestly doesn't look like the small amount of water level has changed. Intex did honor the warranty and is shipping a new liner but now I wonder if the puddles of water was from condensation instead of a leak. There is still water under the pool between the liner and the XPS foam but since it rained last night I can't tell you if its more or less.
I was honest and told the rep that I could not find a hole or see an actual leak but if it was a seam leak on bottom and I wasn't sure how to see it with water in the pool. I've had a few Intex pools but this is the first time I've used the foam insulation boards under my pool too.
