My first time closing my pool after years of hiring it out and having issues. Was planning on using my compressor to blow out the lines and I read here that you can directly connect to the pool pumps drain valve. My compressor hose has quick connect fittings. Does anyone know what adapters/fitting might help make the connection ? The pump is a hayward northstar .
Also is there a safe PSI range to operate at ?
Thanks !!
Thanks !!
