- Oct 16, 2020
- 263
- Plaster
- Jandy Aquapure 1400
Hi! I know there are many similar posts from this season and years past but I wanted to get feedback on my plan. I've opened my pool by myself before (with help from TFP), but never closed it. I'm nervous. A big shout out to Newdude, who has already talked me through some of the preliminary steps.
I have a 15x30 in-ground pool. One skimmer. Dual main drain. Three returns. Cartridge filter. SWG.
1) Balanced water. Add correct dose of polyquat 60, circulate.
2) Robot to get rid of debris
3) Drain pool water to four inches below returns. Remove skimmer basket and return eyeballs.
4) ?turn off power at circuit breaker
5) Turn valve to close off main drain, but open up skimmer
6) Use Cyclone blower with hose in skimmer- turn on until no more water through returns. (I have short hose and adapter)
7) Turn valve to close skimmer and open main drains
8) Cyclone on until no longer seeing bubbles from pool floor
9) While cyclone is still on, turn valve to close off main drain for air lock (do I turn this back to open skimmer or to closing inlet)
10) RV antifreeze in 3 returns. Plug returns. Antifreeze in skimmer (down skimmer hole and also in area that would house basket in summer).
11) Gizzmo in skimmer
12) Add extra empty bottles to skimmer to take up space? Add an empty bottle with a little antifreeze to place where weir door usually is (I heard about that on YouTube, might be silly)
13) Remove all plugs from equipment.
14) Cover pool (hopefully with my husband's help, as I almost fell into the pool when I opened it alone)
Questions:
a. Do I remove filter cartridges before step 4?
b. In other threads, I've read 'filter set to recirculate'. I don't know what that means. Is that something I have to do with cartridge filter?
Thanks so much for looking. I can take pictures of the equipment tomorrow if needed
Questions:
