We have ND (not detectable) iron in the water but eyeballs / baskets etc turn yellow over time so must be some.
When we had the pool resurfaced contractor put in Orenda SC1000 to suck up metals in fill water
SC1000 bottle says maintenance dose is 6oz/10000 biweekly and is needed only in the summer so I put in a maintenance dose
Bottle says startup dose will deplete FC, but nothing about maintenance dose but checked anyway and sure nuff
Stuff added about 8am
Checked at about 4pm and found FC gone
Added couple gal 10% chlorine and FC went right up to 5 and stayed there. Also had to add acid.
So seems even maintenance SC1000 depletes what is in the pool but after some time, this process ceases
Called Orenda who said…
SC1000 binds stuff; after binding it can bind no more; so after a few hours it can no longer bind chlorine; after a few hours put the chlorine back
They are thinking to change the label
They are considering changing maintenance does to 3oz/10000 weekly
So with SC1000
After 7 mo eyeballs are white; nice
6oz/10000 will bind up FC so after eight hours must put it back
So actual cost is cost of SC1000 plus cost of chlorine and acid plus time
Dunno if I will keep on using it but white eyeballs and baskets are surely nice
So with SC1000
