I am just coming on SLAMing my pool. Water is cleared up and looking great!
This morning I did a complete set of tests, here are the results:
FC 6
CC 0
pH 7.2
CH 425
CYA 30
TA 80
Salt 3000
If I am understanding things correctly, here are my next steps:
1) Add salt - the manual for my clorinator says its should be "around 4000ppm, but never below 3000ppm". According the calculator I need to add about 200 lbs of salt to bring the level to 4000
2) Adjust CYA - according to the recommend levels chart for a SWG pool it should be between 70-80. The chlorinator manual says to "keep the stabilizer reading between 30 and 60ppm". Should I go with chlorinator manual levels? If I target 60, the calculator says add 100oz.
3) CH level is a little high, the pool is pretty full right now so I don't need to add water, is there something else I should do to reduce this?
Also, then tonight I am going to backwash the filter and add some DE.
Anything else I should be doing? Can I add salt and stabilizer at the same time or should I do one or the other first and then wait a while between?
FC 6
CC 0
pH 7.2
CH 425
CYA 30
TA 80
Salt 3000
