Finished SLAMing and am starting normal maintenance. Some questions:
1. For the CH test, I see the color change from red to purple, and after a few more drops it seems less purple and more blue. Do I stop when the red changes to purple, or when the purple changes to what I guess is blue (although it seems to still have some purple in it)?
2. For the TA test, I see the green color turn first to pink, then after a few more drops it looks either very dark pink (according to my "other half") or actual red (according to me). Do I stop when the pink is evident or to the very dark pink/red point?
3. I see that the ideal range for CH on the laminated TF-100 instruction sheet for a masonry pool is 250-400 ppm. However, the ideal CH level for a plaster pool with liquid chlorine in the Recommended Levels article in Pool School is 350-550 ppm. For an elderly pool (vintage 1977), possibly replastered in 2018 by previous owner's pool guy, what actually is the ideal (and acceptible minimum and maximum) range for CH?
Thanks.
Thanks.
