Hi from the UK, fairly new to all this and struggling this year, sage advice required please.
In a nutshell - started about 6 weeks ago with an Intex 4ftx15ft vinyl, the included cartridge filter/pump and a chemical starter pack.
Initially all was well, I used the recommended chemical amounts at the start, used test strips, checked chemicals daily and everything appeared to be steady. The filter was taken out and washed every other day and was always remarkably clean so I assumed I was doing a good job…
Then the weather turned and I covered the pool for about two weeks, I left the filter running for 6-10 hours a day and maintained my chemical test and filter regime.
Finally with some good weather forecast I took the cover off and noticed that the bottom of the pool was very dark, I also realised I hadn’t put any algaecide in for about 4 weeks and suspected that was the reason for dark pool bottom. I had some algaecide, mixed up the correct dosage and added it to the water. I decided, maybe wrongly, to give the floor a good brush which created a dust cloud of doom. The bottom was no longer visible, but I had faith in the cartridge filter and fresh algaecide to do their jobs. Sadly the cloud of doom wasn’t showing any signs of dispersing, even with me changing/cleaning filters 4 times a day (and tipping the dregs left behind in the filter each time).
After about a week of checking chemical levels, changing filters I bit the bullet and got myself a proper pump/filter which is an Emaux 350, circulates around 72ltr per minute (60x72 = 4320ltr per hour). This was a game changer, it cleared the pool so I could see the bottom in under 24 hours, the flow rates seem to work well with my cheap Intex water heater too so I was very happy.
But…
You could still see the floor was dusty, but if you gave the bottom a little brush the cloud of doom would return and another 24 hours was required for it to settle down again, but then so had all dust settled again too and a vicious circle would ensue.
I’ve tried to vacuum both with my Intex cordless vacuum (Crud, it doesn’t filter out the fine dust and blows it everywhere, but works great on sand, bugs at the bottomand using my filter/pump vacuum works to a point, but it still kicks up a dusty mess because it can’t vacuum up everywhere the brush is being pushed along to.
There’s definitely a lot less dust/debris at the bottom, but the continual brush, cloud, filter cycle is annoying to say the least.
I’ve taken some readings this afternoon -
Cyanuric = 48mg/l
Total Ch = 2.09mg/l
Free Ch = 1.76mg/l
Combined FC - TC = .33mg/l (my own calculation which may be wrong?)
Pool pH = 8.13
I’ve added some pH minus this morning as that has crept up since yesterday (7.57)
I’ve attached some pictures which may give a clue to somebody, you could see the bottom this morning, but I wouldn’t say it was clear, just a lot clearer than it was with the cartridge filter. I’ve subsequently hoovered about 3 hours ago and this is the current state of play
Thanks in advance for any assistance
But…
Cyanuric = 48mg/l
Total Ch = 2.09mg/l
Free Ch = 1.76mg/l
Pool pH = 8.13
