Cloudy water
Apr 2, 2017
31
Lake Charles, La
Noticed this morning my pool was cloudy. 9’ deep and could barely see the bottom drain.
Results from last test on Saturday (5/5)
FC 2.5
pH 7.6
TA 90
CH 300
CYA 40
Tested FC on Wednesday and was down to .5 so decided to add enough to bump up to 8 as we are having a lot of swimming this weekend. Noticed pool got cloudy. Maybe that’s normal, but just curious.
Sounds like your water got stressed from the low FC and it on the verge of a SLAM. It's definitely time to bump that FC to at least 10. With that CYA of 40, 10 is only half the SLAM level anyways - perfectly safe. Run it that way through this evening and through the weekend. If you let it fall a little for the visitors it won't matter a whole lot. But when Sunday gets here and all the swimming is done, I'd do an overnight (OCLT) test to see if you need to SLAM.
