- May 28, 2023
- 76
- Plaster
- Pentair Intellichlor IC-40
August 2023 I treated my plaster pool with Jacks Magic Stain Solution #2, I wish I hadn't. Closed the pool in September (FC/CC off), Opened it April 28th, 2024. Water looked fine, but once I brushed I had some sediment on the bottom, it stirred up and clouded the pool, a few days later it seemed to be clearing up clear. Until I brushed again and threw the Polaris 280 in. I have been battling cloudy water since. Brushing makes it worse. I can still see the bottom in 8ft, but it is not crystal clear. I have been running filter about 16 hrs a day, increased to 24 hrs today. I have cleaned the carts once so far, they were pretty gunky. AND of course my FC/ CC is still messed up. I am not sure if I should try to SLAM, I have been hoping it will work it self out, but I am not so sure now. Drain and refill not an option, all water added after opening in spring was rain water. So what I am asking is, should I try to SLAM to fix my FC/CC issue? Should I wait longer? Could something else be causing the cloudiness? Other options?
Thanks in advance.
FC: 0.6
CC: 6.0
PH: 7.6
TA: 70
CYA: 70
CH: 350
Temp: 76
Thanks in advance.
FC: 0.6
CC: 6.0
PH: 7.6
TA: 70
CYA: 70
CH: 350
Temp: 76
