FC 9.5
CC 0
pH 7.2
TA 100
CH 300-325
CYA 60ish
I've had cloudy water a couple times last 3 weeks. The first time solar cover had been on for over a week and plenty of small debris had gotten in pool, but this was before it was warm enough to swim and FC was 3 the day I uncovered and water was slightly hazy but not green. I was running pump at least 50% of time and SWG on low setting because FC had been above 5 every time I checked, usually 6-8. I questioned early algae and put in 5 gallons 10% bleach to FC 28 and upped SWG and ran pump 24/7 since then, FC was 14-19 for 5 days and water cleared within 24 hrs of starting. I didn't do a real SLAM obviously
FC has been consistently above 7 since then. I added CYA since to target 70, but I still read about 60 testing it today so added another 35 oz CYA to get to 70 before going to 80. I'm still not good at that test.
Anyway, water was slightly hazy yesterday, like I see the bottom drains well at 6 feet deep but not crystal clear like all last year. pH was 7.7 before I added CYA 2 weeks ago and it dissolved within 3-4 days. pH has slowly fallen to 7.2 today despite several days of swimming, splashing, and SWG running 40-60% 24/7. All last year I added acid every couple weeks 1-2 cups at most to keep pH below 7.8 and several times to pH 7.2 to get TA to 70 to help pH rise.
Questions:
Woudl 35 ounces CYA decrease pH from 7.7 to 7.2? And gradually over 2 weeks?
Can very low algae levels cause pH decrease?
I've read calcium can cause haziness depending on pH, but I've had the haziness now at pH 7.6-7.7, then nice and clear and now again at 7.2. Does that rule that out?
My solar cover has one hard season of use, 12 mil blue cover. Any reason that could affect pool after a week sitting there with pump and SWG always running?
We got a heavy rainstorm 5 days ago adding 2 inches on water but minimal debris which I suppose could have affected pH because it was closer to 7.4-5 before storm. Thought? Maybe I'm confounding myself with too many variables.
thanks in advance for any help.
CC 0
pH 7.2
TA 100
CH 300-325
CYA 60ish
Questions:
