I’ve had the pool three weeks since I bought the house, and it went from crystal clear to this cloudy, foamy, smelly mess. When I got the house, these were the numbers:
6/4/24
TDS: 2800
pH: 6.8
TA: 110
CH: 186
Optimizer: 5
FC: 15
TC: 15
CYA: 150
Pool company had me add some stuff to get rid of metals, which caused a filter clean. The drain plug on the filter housing had been stripped prior to my intervention, and blew out when presurizing. I was without the filter for a little over a week, but after a few days of no pump operation was able to get a band-aid solution in place until I bought a brand new filter and housing.
Then the cover stopped working, and we got 3-4 days of heavy rain, and it all went downhill. Water got cloudy, smelly, and foamy, with these numbers:
6/19/24
TDS: 1300
pH: 6.7
TA: 132
CH: 176
Optimizer: 3
FC: 0.3
TC: 0.4
CYA: 159
I proceeded to dump 20 gallons of 15% liquid chlorine from Fleet Farm in over the course of a few days and it my FC levels stayed the same, with my TC slowly creeping up to 0.7.
So I swapped 3600-ish gallons of water, and added 2 gallons of chlorine every hour for 3 hours. Then I waited a few hours and got these number from the pool store test:
BEFORE water swap, 6/25/24
TDS: 2100
pH: 7
TA: 186
CH: 176
Optimizer 2
FC: 0.3
TC: 0.7
CYA: 101
AFTER swapping 3600-ish gallons
6/26/24
TDS: 1200
pH: 7.3 (I’ve been airrating to increase pH so I can lower and reduce my TA
TA: 200
CA: 183
Optimizer 2
FC: 13.2
TC: 14.8 (does this make CC 1.6?)
CYA: 97
Phosphate: 300
My TF-Pro kit comes today, the test results above are from the pool store. My cheapo test strips have been showing my CYA around 30-50, but the other numbers are consistent with theirs. I’m considering swapping another 12,00 gallons to get my CYA and TA down and hopefully get rid of the cloudiness and foam.
Hope someone out there can help. I’m ready to tear the pool out and plant a garden.
6/4/24
TDS: 2800
pH: 6.8
TA: 110
CH: 186
Optimizer: 5
FC: 15
TC: 15
CYA: 150
6/19/24
TDS: 1300
pH: 6.7
TA: 132
CH: 176
Optimizer: 3
FC: 0.3
TC: 0.4
CYA: 159
TDS: 2100
pH: 7
TA: 186
CH: 176
Optimizer 2
FC: 0.3
TC: 0.7
CYA: 101
6/26/24
TDS: 1200
TA: 200
CA: 183
Optimizer 2
FC: 13.2
CYA: 97
Phosphate: 300
