Closing on house and grabbed water sample. Tested with TFT100 Pro - Questions
briggss3
76
Lake Jackson, Texas
CircuPool RJ-60
What do I need to do day 1 on this pool? Taking possession in 10 days. Planned on putting on SWG out of the gate (seperate thread). Snagged a pool water sample on my final walk through. It's got the tablet floater in the pool and is a standard Cl pool.
Coming off winter in SE Texas. Pool water is still chilly. Minor leaves etc noted in pool. But water is crystal clear.
Grabbed a sample on the surface by the steps. Used a 20OZ sport water bottle I had laying around. Here are my results (questions on salt test color later)
Used FAS DPD test.
FC is 1 ppm or less
CC is 1 ppm or less
TA is 130, maybe slightly less
CYA is >100 and was only 1/2 way to 100 mark
Salt is 1000 ppm
On the salt having a hard time estimating right color called "salmon".
Start
Drop 1
Drop 2
Drop 3
Drop 4
Drop 5
Drop 6
Drop 7
Drop 8
Drop 4 is your endpoint. Its as soon as it turns pink. You can drop a half a gallon of Cl just to keep the pool from turning green. You need to do the diluted CYA test. Prepare to drain the pool or most of it. Please fill in your signature with the pool specs so we can help you better.
I don't know all the specs just yet. Still getting a handle on that. Took a bunch of pics of pumps etc. Will post that soon and update my profile. I guesstimate it is between 15K and 25K gallons. The owners weren't sure when I asked them.
