Closing kits
Water Cat
Active member
Aug 30, 2020
43
ON
Do closing kits such as the bioguard closing kit expire or lose their effectiveness?
I have a unused closing kit that has been stored in the garage for about 10 years. Is this still good or is it no good anymore? Garage is insulated and not damp.
Does the algaecide list copper as an ingredient......can you give me the ingredient list or a pic of it?
Is that "shock" a granular product? Again, what is the ingredient?
Are you actually having scale problems? Most vinyl pools don't have calcium issues to worry about......
Maddie
The Algicide does list copper as a ingredient
The shock is a powder in a bag
Municipal water here is extremely hard and calcium is definitely an issue from unsoftened water. Water softeners are standard in homes here. Outdoor water is not softened.
My main concern is how well these products will work after sitting in the garage for so long. Is it still ok to use them?
The kit is the bioguard hibernate one
The age doesn't matter, you don't want to use any of those products.
Copper algaecide is not a good item to use. Whatever the shock is isn't going to be good. It either has CYA or calcium, neither of which sound like a good idea in your water. And you really don't need anything for scale.
Best to just throw them all out.
I would NOT use the copper algaecide. The shock is probably fine to use- it either has CYA or calcium in the mix but one bag shouldn't be a problem if your testing shows you can afford it.
Those products are fine if they've been kept dry and out of sun.
Maddie
