Tried to figure this out by searching other posts but I'm a neurotic newbie and need reassurance! I was following the TFP closing plan but goofed. 5 days before our scheduled close date I tested; based on results I added acid and calcium but then I messed up by adding (at the same time) chlorine to bring it up to shock level, before I retested the pH. So when I tested again, pH still showed high, then I realized that the pH reading was not going to be valid until after the chlorine came down. So, I rescheduled the pool guy to move our close date out another 10 days. It's been very rainy and cloudy here, so the chlorine levels have been dropping very slowly. Was 17 on 10/17, now 5 on 10/29. Here are my full test results today including pH which I'm not sure I should rely on:
FC: 5
CC: 0
TC: 5
pH: 7.8
T/A: 50
CH: 420
CYA: 40
Temp: 57
So assuming it actually is pH of 7.8, the pool calculator returns a CSI of -0.11, well within range, but everything I read says bring pH down closer to 7.4 before closing. So am I okay? Closing is scheduled for 10/31. Any advice on recommended chemistry adjustments would be appreciated.
FC: 5
CC: 0
TC: 5
pH: 7.8
T/A: 50
CH: 420
CYA: 40
Temp: 57
