jovian1998 said:Hi all,
I closed the pool last year for the first time following this thread, blowing the pipes, put some antifreez and lower the water level below skimmer. This year as i opened, I had to replace the liner cause it was wrinkly. My question, is there a possibility that I didn't do something right during closing that triggered the liner to wrinkle?
Thanks.
joconnor72 said:I winterized my inground pool last year, but i couldnt get my 6hp shop vac to blow out the main line where i could see air bubbles coming up from the bottom before i closed the valve. My pool guy came out last year with a mighty blower vac and was able to do it for me. This year i tried again with no success of seeing air bubbles while blowing the main intake line before i close the valve to create the air lock, so i poured 1 gallon of RV antifreeze down the pipe then repeated the process of blowing the main line and closing the valve without worrying about the seeing air bubbles. My question is should i worry about the main line because of no visible air bubbles, or should i purchase one of the mighty blower vacs for pools to blow out the main every year?
my pool is gunite/plaster 8feet deep end, built 1989, 35,000 gallons sand filter 1hp pump and i live in indianapolis, in
joconnor72 said:Mike-are u closing or closed yourself this year? If so did u blow out main with shop vac? I'm not that concerned but the balboa mighty vac is 272 bucks and I watched my pool guy get bubbles out when he closed for me last year.
mschmidt33 said:I did it all myself... used a 5hp shop vac that did great on all the lines but could not get bubbles on the main. Should I worry? How about a less costly option that will do the trick?
No need for clarifier, metal free or phosphate remover, algaecide is likely copper based and not good long term. None of these are required.DanaSC said:I called Leslie's. They said their closing kit comes with chlorine, clarifier, algaecide, metal free and phosfree. Would it be easier to just use that? I'm on the BBB but I have to usually convince my husband to go the BBB route because he sees that the pool store methods are usually "easier." Any help would be appreciated here!![]()
