Hi all,
My pool is currently closed. I had an issue last winter with too high of pH causing scaling. I've been checking the pH and adding acid every other week or so. Every time I check it, it has risen to 8.2. The TA was fine when I closed it and has been at the same level, 70, every time I check it. What would cause this rise?
home
Build Type: Plaster
Volume: 16000 gallons
Latest Test Result Summary:
FC: 3.5
CC: 0.0
pH: 8.2
TA: 70
CH: 300
CYA: 40
SALT: 3200
home
Build Type: Plaster
FC: 3.5
CC: 0.0
pH: 8.2
TA: 70
CH: 300
CYA: 40
SALT: 3200
