Hi everyone...
A “professional” had closed my inground pool last month. Today when I went to set up the pool cover pump, I noticed that the multi port valve setting was left on recirculate as
opposed to the closed setting. Will that cause any problems... will I have an issue over the winter ? Opening in the Spring? All power had been shut off to the pool/pump since the date of close. I witnessed the pool guy blow out the lines as well as lower the water level.
