Hello,
I am in the process of excavating and have run into heavy clay. The environment we live in is very cold, and has a relatively deep frost.
I have found some bits using the search function that sort of address this, but I'm still not entirely clear on the BEST approach to setting the walls.
If I understand, it will be risky to set the steel pool walls directly on the clay(expansion), but is there an overall consensus on how to correct this? Reinforce really well and put it right on the clay? Dig a bit deep and level with 1/4"-1/2" of gravel? I'm not super concerned about an additional cost, just want to make sure that this is as solid as it can be.
Thanks in advance.
Thanks in advance.
