I keep hearing that if you can afford, go big and use at lower power. So, since this is a new investment, that's what I'm aiming for. Pool is roughly 20K gallons, so either are enough overkill.
I have a new pentair intelliflo 3 pump with relay, currently just on intermatic timer 24/7, using pump for schedule. No other fancy automation. I will probably wire the SWCG it up to the pump relay.
Core55 seems good, it takes up less room in the plumbing and doesn't need wall space, which I like. My equipment pad is pretty cramped. The dowside used to be the Core went in I guess 25% increments with only 4 settings, now they have 6 settings, so you can do 15%, 30%, 45%, 60%, 75%, 90%. I mean, I don't really need 5% increments or tighter, I don't see much advantage to that. The Core series seems much less common than the RJ. But I like it's all-in-one design, at least in theory. It only needs about 7" of space, but needs some above/below clearance.
RJ60, I see the RJ45 is hugely popular, I imagine there is not any downside to going the 60 other than slight price increase. The RJ45 needs 16" and another 4+ for the relay. I saw with the RJ that if you run at low GPM, you should invert it (so it flows --\_____/-- instead of --/`````\-- ). I also see there is a vertical space saving option, not sure how that would be affected by the extra low GPM though. With the RJ, you have a separate control panel, you have wiring from source to control panel, and from control panel to flow switch, and from control panel to cell. But you also have some cool information available, such as water temp, cell voltage, current, salinity.
Price - the same, or within a close enough range.
So, which would you go with? How useful are those pieces of info? Useful enough to outweigh the longer installation run?
Do you think there's any difference with regards to pump flow / efficiency? Any other pros or cons to weigh in on? Appreciate it!
