I am trying to get my pool back to sparkling green after all the oaks have dropped there junk and also realizing I had algae.
I just bought a new test kit. Taylor k-2006. I have a 21,200 gallon in ground, plaster pool.
Tested green water and had high CYA (70) and and high CH (400) so I decided to empty water to steps where I had visible black algae and scrub it with a brush and chlorine tab. Added water back.
CYA (36) CH now (260) but my Alk was 180 and PH was close to 8. I added a container of muratic acid to bring down ALK and PH. Tested and PH was 7 and alk was 50 and now my FC was about 7. Running water feature to raise PH again. I waited 30 minutes and started adding chlorine to try to SLAM the pool. I added 7 128oz 8.25 chlorine over about 30 minutes.
Now my trouble is I can't get an accurate reading for FC and the other tests work but do not seem to be as clear. My water sample turns bright red immediately after adding R-0870. I have added more than 30 drops of r-0871 and it does not change the color at all. I have done this test several times over a day and a half and I still get the same result.
I am not sure if the test or reagent is bad, or does not test that high. Should have been around FC 34 assuming my earlier tests were accurate.
My water is clearing but still cloudy. I added another 128 oz of bleach just to make sure I have a high level assuming test is off.
What should I do next. My most recent results are:
FC ??- still bright red after adding R-0870
PH 7.4
ALK 100
CH 260
CYA 36
PH 7.4
ALK 100
CH 260
CYA 36
