Chlorine output from pentair ic40
briansturgeon
118
Cincinnati, Ohio
Can someone tell me if running my pump at a higher rpm say 2000 will produce more chlorine than running it at say 1200 rpm for the same amount of time? I am guessing it will but not positive. My cell is on and the flow rate is sufficient at both speeds to keep the cell producing. Jus wasn't sure if the more water pushed through it at a higher rpm meant more chlorine or not. Thanks.
