Shocking the pool means keeping the FC at shock value (16) until the water is clear and you pass the overight chlorine loss test. You should be testing every hour initially until the FC begins to hold, then you can move to every few hours.
Keep adding chlorine. Keep FC at 16. It's going down because it's killing algae. You need to kill the algae faster than it can reproduce. This is a battle to the death. Knock it down, and keep hitting it while it's down, again and again and again until it can no longer get up.RSAnative said:Good morning. So I added the chlorine yesterday and it brought the FC up to 6. This morning it's back down to zero. Do I repeat the process? Use more chlorine this time? Why won't it hold chlorine? PH went down a little bit as well. I did not keep the tabs in last night. Should those of been in as well?
RSAnative said:The three tests, FC, PH, all?
RSAnative said:Treatment two underway! Question; after I've stabilized the FC, do most people here just use liquid bleach to run their pools? No tabs?
Wherever it works out cheapest or most convenient.RSAnative said:I need up switch over to Swg. And do you buy the liquid in grocery stores or pool shops ?
It is best to have the pool cleaner out of the pool when shocking. The higher FC levels can sometimes affect the internal metal parts. High FC can also degrade the bags.RSAnative said:Is it ok the run my baraccuda while shocking?
