Commercial outdoor pool and hot tub... 140,000 gallon pool and 2,500 gallon hot tub. Our chlorine feeder is signaled to feed chlorine based on ORP readings even though ORP from what I understand is not a direct measure of chlorine. I am struggling to keep chlorine readings steady. Our ORP is higher in the morning then falls throughout the day as UV rays hit the water. My question is how do we set the ORP setpoint so that we are not overfeeding in the afternoon when chlorine levels are within the acceptable range but ORP is low and underfeeding in the late morning when ORP is high but chlorine levels may be low. Some additional notes: PH is kept at 7.4-7.5 using a acid feeder, alkalinity kept at 80 using sodium bicarb, CYA is between 30-50. FC I want to keep between 2-4, CC is currently 0. (Free chlorine is climbing as high as 5 in late afternoon after feeding chlorine all afternoon due to low ORP which is what I'm trying to prevent)
