The amount of powder is not critical. If your sample turns any intensity of pink in the presence of chlorine, you have enough powder. Don't worry about it. Here's the two most common testing errors for that test.
1. The sample never turns pink so many assume their powder is bad when, in fact, they simply have no (as in ZERO) chlorine in the pool.
2. This pertains to all drops based testing.....not just chlorine. You must continue to add drops until the last drop you use results in NO color change whatsoever. Then you subtract that drop that made no difference and what's left is your true result.
As stated above, the bottle of reagent should be held vertically and the drops allowed to fall from the tip.
