My pool is very stable and the chlorine always drops 2.5ppm per day. Normally I add 1/2 g daily but sometimes I'll add 1 g and skip the next day. Either way the pool ends up using chlorine at the same rate. I expected higher chlorine levels would decay at a faster rate but that doesn't seem to be the case. If the loss rate is independent of chlorine level (at least up to some point), can I do a triple dose every 3 days, or even less frequently?
I was wondering because I'll be away for 5 days and want to over-chlorinate before leaving. I couldn't find any posts that directly address this question.
