Hey guys,
I’m new to this site, and have read many threads on similar issues, but none of them seem to match up with what I have going on.
I have an AquaLogic AquaPlus control panel with a Hayward 15-W cell.
I had my pool water independently tested twice a week or so ago and the salt level has come in around 3,000, yet my chlorinator is reading 5,400 or higher before it shuts off. I just tested it with the salt scape test strip (these things seem to be junk and never come close to the store or my chlorinator readings) and it says my salt is around 2000. So I’m fairly certain my salt level is no where near 5,400 like my panel shows. The voltage and amp reading at start up stays around 23V and 9.5 amps (8.5ish at night). I checked the main board and did not find a burnt solder joint on the back side (as some people did when investigating this issue) The 20A fuse reads at 0.2 ohms. And, from what I’ve found, all voltage readings are between 21 and 23V. It’s been over 90 degrees each day so the pool water is continuously over 85 degrees, but I’ve even tried checking at night when the temp is lower and the chlorinator still shuts off due to high salt and amp reading.
I have read all sorts of articles and forums and they all say that a bad cell would not show a High reading, but 1. I’m not understanding how it would “never” send that reading as it fails, and 2. I’m not sure what else could cause this issue at this point.
Ive been battling algae and unable to use my pool for a couple weeks now thanks to it having zero chlorine production and the pool techs are all backed up due to high demand (plus I don’t want to pay someone to fix something I can do myself) and Hayward’s tech support just told me that the salt was too high or that the pool temp was high and that can cause this. It is over 90 degrees just about every day in the summer here in Charleston, so that answer doesn’t work me for either since the chlorinator worked fine before.
if anyone has come across this issue and found the cause please fill me in. Also, if anyone has tried out a generic salt cell to replace their Hayward, please fell free to share your experience, as I am close to The point of just buying a generic cell, swaping it out and seeing if that fixes it.
Thanks in advance for The information and any advice/ help you are able to provide me with!
