The pool industry hasn't acknowledged the effect CYA has on the active chlorine content. The 1-3 ppm recomendation was for a pool with zero CYA.
myrddin said:Man I am confused... My test kit shows CL higher than 3.0... And shows it needs to be like 1.3...
myrddin said:Ok... Thanks for helping me... Soon as I get the kit I will try to get the results. I will also chk the pool agn today to see if my stats have changed... I did add baking soda as recommended...
myrddin said:OK guys, I have my first test results... I may retest tomorrow but feel like I am close if not dead on:
PH 7.5![]()
CL 5+ Typically you don't test with the OTO test when you use the FAS-DPD
BR 10+ Unless you have bromine tabs in the pool this is not actually true. The same block test is used with different chemicals to test for Bromine - ignore this
FC 8.5Min is 7; need to have enough that you don't drop below this during the day - 8.5 may not be high enough - 12 or so may be needed - assuming you don't need to shock
CC 0.5Zero to 0.5 is generally fine.
TC 9 No need to post this - we can add the FC and CC next time.
TA 190 Eventually you will probably want to bring this down - not your first priority however.
CH 260 (may repeat)This is a hard test without the speedstir they say. I have gotten better at it over time. Go fast and work with an even and steady pace.
CYA 95 or 100 (this is an odd test, I drop into the tube till I see no sign of the black dot at all) I assume this was nearly to the top? If so retest with half pool water and half tap water and multiply the result by 2. The test is less accurate close to 100. Chances are it could be over 100 but since you got a less than 100 result you may be correct.
myrddin said:The water looks clear... Cant remember which would pump the water out... I am guessing if I close the skimmer and put the valve on winter or whatever the setting is it will pump out??
If you are diligent about keeping you FC level up, 8 ppm minimum for normal FC (from poolcalculator.com and cya 100 ppm), then you may/should be able to survive until you winterize and drain. Use bleach/liquid chlorine to chlorinate so you don't add anymore cya this year.myrddin said:What do you recommend, I can remove water or keep as is... I have the pucks out and Chlorinator off... I have not added anything to the water at all for at least 2 days.
