Hi all,
I have a vinyl IG pool. 19,400 Gal. Sand Filter.
I test my water regularly with the TF-100 kit and periodically take water to the pool store for a test. They need a record of my chemistry to support equipment warranty requirements. Anyway, my water is usually fine when they test it, and theirs tests are usually pretty close to my own results.
I tested my water last night and got the following results:
I added some acid and stabilizer after my test and the pool store test shows the following results
FC 1.9
pH 7.6
CC 2.2
TA 115
CYA 46
CH 100
So everything looks great... except my water is still green.
What do you recommend?
Doug
FC | 6 |
pH | 8.2 |
CC | 0.5 |
TC | 6.5 |
TA | 120 |
CH | 150 |
CYA | 0 |
FC 1.9
pH 7.6
CC 2.2
TA 115
CYA 46
CH 100
Doug
