I have been trying to get my Rheem 8450ti heat pump working properly with it in pool mode or spa.
Whatever I tried, the heater would trip and he high pressure switch. The check valve flap was barely opening
So I removed the flap and raised my flow rate to 40+ home. Bingo! The heate would work on pool with diverter completely open to heat pump. Spa worked with that same handy slightly diverted.
My question are. Is this check valve hoint to be ok being removed? I can insert a jandy valve in housing to bypass heater if ever needed.
