Recently we switched our pool from Chlorine to an Intellichlor SWG and the difference in the feel of the water was quite remarkable- we couldn't believe it. At the time we didn't really want to splurge for a second salt cell for our separate Spa, but we'd love to get the same / similar feel as we have in the pool. I'm certain i could add a bit of the pool salt to the Spa. On an old / closed thread it said be sure to measure what you already have, so I took my sample into the local Leslies and had them test it.
Question 1: PPM is PPM regardless of the size of body of water. Size only matters when i calculate the quantity of Salt to add. Correct? So if my Salt level is 800 ppm, it doesn't matter if i said it was 1000 gal when it's only 600 gal, the PPM is accurate for either, no adjustments needed.
Question 2: What target Salt level should I be shooting for? the Pool's ~3600ppm for the SWG. the Spa doesn't have the need to be that. How much is too much salt?
