- May 4, 2011
- 634
Yeah, I found out a few things.BethyM said:Speedo: were you using the metal plate that came with them? I think the Aluminum walls are going to be a problem for us but glad you found a solution that works with the steps! The steps look HUGE sitting in the yard![]()
- From what I gather, the walls are aluminum (coated?) on the outside, it's also made of steel. The magnet will stick on the inside, enough to feel it stick, but won't stay.
- Metal plates zip tied to the ladder aren't even close to keeping it in place (the air inside forces it to float)
- Air inside forcing it to float actually helps keep it under the steps lip
Did your installer assemble the steps? We had to put ours together. It does look pretty tall when out of the pool. It will look much smaller when in use.
I keep mine out of the pool when not in use and turn them on before getting in and after I've taken them out. Just for fun I tried to turn them off from outside the pool. Doesn't even work when pointing directly at them from about 4-5' away, 2' of which was under water.Big_kid said:Word to the wise- the remote is DEFINITELY NOT water resistant at all. I managed to get water in it somehow. It was working last night, this morning I found the indicator LED on it glowing and the button non-responsive. I opened the remote and found condensation inside, so I'm letting it dry out. Hopefully it will start working again. Even if it doesn't, for the price I'm not going to complain.
