Parts needed:
1. A chemical pump
2. A Stenner injection valve ( with or without checkvalve)
3. A chemical storage tank
4. Timer to run it
My Parts:
1. $83.20 Ebay does coupons for 15% or 20% off events once or twice a month. https://www.ebay.com/itm/DISHWASHER...201273?hash=item4b27f95e79:g:0FQAAOSwORVZznDh
2. $10.93 https://www.amazon.com/gp/product/B01DUS1C7S/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
3. $18 5 gallon tank, might not be the best option but it works so far http://www.bigr.com/vp-racing-sportsmans-container-/265574.html using 20% online coupon can be found using google
4. $40 smart switch which I schedule using "smartthings" https://www.amazon.com/GE-Appliance...ocphy=9016385&hvtargid=pla-307093604147&psc=1
My Schema:
Chlorine Tank -> Injector Pump -> Chlorine Tablet feeder drain plug (tablet feeder is set to full flow to get it to the pool a quick as it gets into the feeder) Tablet feeder has no pucks as well. They say mixing liquid chlorine with trichlor is bad and I don't care to find out.
My Installed Images:
1. Pump:
2. Injection valve:
3. Tank: ( Modified with a one way duck valve to keep fumes in so when sucking if it draws negative pressure it sucks in fresh air, but doesn't leak any air)
4. Smart switch: (on a GFI outlet)
Video:
https://www.youtube.com/watch?v=tO9hJRA5yJo&t=6s
1. A chemical pump
4. Timer to run it
My Parts:
My Schema:
1. Pump:
2. Injection valve:
Video:
