Happy Friday all!
I will be changing the ball valves on the suction lines this weekend as the existing ones are old and leaking. My ball valves sit slightly higher that the water level of the pool. I will be busting out that sloppy looking concrete that was done by previous owner. My question is this: Will I have to worry about water continually spewing out when I cut the pipes to replace the valves? Also, do you recommend using the "Rain R Shine" PVC pipe glue?
Thanks in advance.
Thanks in advance.
