Change Intermatic T104R timer to Suraielec WiFi timer
SolventSolution
3
Poway
Hi all,
My old Intermatic timer has a worn out switch mechanism which will no longer trip the off. I purchased a Suraielec WiFi timer to upgrade. I am a bit lost on how to move the wiring over. It looks like both the Pentair filter pump and the pentair booster pump are connected to switches which then go to the timer (yellow wires). The two black wires and ground connect to the pentair heater.
Any help is much appreciated.
Thank you,
Josh
Yellow wire on Terminal 1 to L & Com 1
Yellow wire on Terminal 3 to N & Com 2
Wires on Terminal 2 to NO1
Wires on Terminal 4 to NO2
If you can't put two wires on L and N, you will have to pigtail a second wire from each yellow.
If you can't put two wires on NO1 & 2, you will have to pigtail a third wire from each black an yellow pair.
After that, it should work the same as you have now.
Reactions: SolventSolution
Perfect! All works great, thank you.
Reactions: 1poolman1
