cement fittings first or glue pipe first?
repairman
203
Lompoc, CA (central coast)
What's the best way to cement in fittings and pipe in pool wall? Glue pipe first or cement fittings (glued to the pipe) first?
If I cement in fittings first, I can wiggle the pipe to get the hydraulic cement in the hole some. Then I can cut the pvc and install fittings and pipe on the outside of the wall.
If I glue all the pipe first, there's probably not much wiggle room for the pipes coming through the wall, but at least I could cover my trenches before I cement my fittings.
What's easiest?
