I have a 25,000 gallon inground pool that uses a sand filter and AquaRite System with T-15 cell. The cell was replaced in July 2019. I'm having trouble getting the pool to produce free chlorine. I cleaned and inspected the inside of the cell and it has no buildup and I see no issues. I did figure out it was set for a T-3 cell and thought that was the issue, but it has been a few days and it doesn't seem to be getting better. When I put it in Super Chlorinate, it seems to have the proper cell voltage and amperage. Any ideas why it wouldn't be working when on auto? The voltage is high and the amerage is 0. Although, it does seem to think it is putting out 39% - which is the setting the dial is at. I got the chemistry tested at the pool store on Saturday and that's when they told me the salt was high, and there is no free chlorine.
Readings when in Auto setting:
3500 (salt is actually a little higher than that. I'm working to lower it a bit)
76 (temp)
33.0v
0.00a
39P
-0
Reading when in Super Chlorinate:
25.5v
6.87a
100P
-3700
It's the voltage and amperage that concerns me. But please tell me if I don't need to worry, and the 39P means it's operating correctly. Thanks!
76 (temp)
33.0v
0.00a
39P
-0
25.5v
6.87a
100P
-3700
