CAT 1000 Flow Sensor?
Hi all, I just bought a Hayward CAT 1000 pH controller that came with a flow sensor but there are no directions on where or how to install it. There is a wire that goes from it to the controller that's about 10' long and the threaded end is 1/8" npt. The instructions for the rest of the plumbing hook up is very clear but this thing only gets an honorable mention stating that it must be installed. Any ideas? Thanks.
https://www.amazon.com/Hayward-CAX-20201-Pressure-Monitoring-Replacement/dp/B005IVZG2S
I would assume that you would install it up stream from where the injection point for the acid would be. You just don't want a valve or two much distance between the two points.
