I've tried lots of things, but I can't get my pH to rise into the normal 7.2-7.8 range. I have a manually chlorinated vinyl pool, 25K gallons. I test with a TF-100 kit. Current test is FC 4, CC 0.5, pH 7.0, TA 110, CH 350, CYA 30, Temp 84 degrees. This is a multi-season problem, no matter what I do, pH starts a slow steady decrease down to 6.8-7.0 range... Things I've tried:
- Raising pH with Borax. Works great, but then pH immediately starts to degrade back down to 6.8-7.0 range on its own. Repeatedly adding Borax eventually pushes my TA too high.
- Using un-stabilized chlorine (calhypo)
- Using a pond aerator whenever the cover is on
Probable contributing factors - I keep the pool covered to conserve heat, and I drain below the return lines for winter, meaning I usually need to add stabilizer each year - either as granules or with chlorine pucks. I am not adding stabilizer at the moment.
I can't seem to break out of the "pH low, TA high" pattern. The water is fine and perfectly swimable - if it weren't for the vexsome little pH test kit, I wouldn't know any different.
Looking for advice - I can't think of anything else to try.
